I have since the begin an incompatibility between the vaio touchpad and the Windows 7, i.e. when is used the program/driver for the mouse (Alps Pointing-device for VAIO), the Windows mouse animations, became static, e.g. the windows blue wheel, don't spin. However, if I disable the Alps touchpad driver from starting, there is no interference with Windows mouse animations, but the additional options that increase productivity, such as scroll and others, no longer possible to use. Does anyone have or had the same problem?
Thanks
JC
