Hi, I have a VGN-FE11S and I use it to connect to a wireless LAN everyday all day.
The VGN-FE11S has a switch to the front right side in order to turn on/off the wireless connection. That switch must be deffective or something, cause although I'm connected, I get discontected out of the blue and the green light on the switch goes off.
Now, if I touch (not move) the button it goes green again and wireless works again!... until i accidentally touch it again...
I thought about putting a tape on in! LOL
Anyone has this problem?
i have a vgn-fs315m and mine will flash if the switch if off
the best thing to do if you dont want to ask sony to check it is to go with the idea you had or try using compressed air to try cleaning the back of the switch
Cleaning the back eh?
Now why didn't I think of that...!
Thx m8
