Hello
I bought a Vaio VGN-FE41S with Windows Vista preinstalled about two months ago (German version). Up to now I didn't manage to get to run the Vaio Update functionality correctly (automatic update). There is always an error message (messageid=0008) telling me that the information about my model could not be found on the server and I should repeat the update-process later. Meanwhile I upgraded manually to Vaio Update 3.0.00.13220a (a newer one is not available at the moment) but the message persists. Is this message an error? If yes, does anyone of you have a solution?
Thanks for help
Victor
Hi Victor and welcome.
Have you managed to Register your Vaio?
I can't think of any quick fixes and it would be best to contact Sony Vaio-Link Official Support and ask them to fix it for you.
Ive got the same problem with my fe48e - it is coming up with the same message. I have tried registering it - but am not sure if it worked. Can you join the club without registering?
Hello,
I have already proceeded to record my VAIO FE48E, but I still receive the error message when you run the Update icon VAIO
Can you help me?
thanks ..
i am getting the same error since i bought my ar 51su about 2 months ago!
I,ve bought myself a notebook yesterday, and i'm encountering the same problem.. is there already a known solution for this? It's a little annoying.
Regards
Hi all,
I have escalated this to Sony, hopefully we should have a solution soon..
I have also the same problem with my F21Z.
Hi bed,
welcome to Club Vaio..
Sony are still investigating the problem as soon as we hear anything we'll let you know..
