Hey All
I Have Sony Vaio AW11Z And I Installed 2 Days Ago Windows 7 (Clean Install)
And Vaio Update Doesn't Find Any Updates What Can I Do?
This Is The Order I Installed Windows 7
1: Clean installes Of Windows 7
2: Graphic Driver & Touch Pad Driver
3: All Windows Update (Successfully Installed)
4: All Software (Like Skype, Itunes )
5:Application Utility In This Order:
1: Sony Shared Library *
2: Setting Utiliy Series *
3: Vaio Event Service *
4: Vaio Control Center *
5: Vaio Battery Checker *
6: Vaio Control Color Setting *
7: Vaio Launcher *
8: Vaio Presentation Support *
9: Vaio Smart Network *
10: Vaio Update *
All Application Utility And Drivers Are From Sony Site ( Beside Vaio Launcher It Doesn't Appear There )
http://www.sony.co.uk/support/en/product/VGN-AW11Z_B/updates
The Only Utility That I Do Not Installed Is Vaio Power Management Because I Couldn't So I Skip It
What Can I Do With This Problem ?!?!
And If The Order Was Wrong Please Tell Me How To Install Windows 7 64 Bit
Because My Computer Is Working Good Now But I Cant Find Any Updates From Vaio Update
Vaio Update Version : 6.3.0.08010
Thanks All
