Hello,
I would like to know if I can download complet drivers for my notebook SVS1512S1ES which will be compatibile with W8.1. Because after clean instalation of Windows 8.1 I can't instal VAIO update and my hotkeys like assist, vaio, touchpad pn/off doesn't work. When I installed battery manager it said that my battery isn't original or somethinkg like that.
Thanks for help.
Hi Matej_Kre1,
Sony does not support a clean install of Windows 8.1. You may find the upgrade guide useful:
http://www.sony.co.uk/support/en/topics/landing/windows8-1_upgrade
You will find the 8.1 upgrade drivers for your model at the following link:
http://www.sony.co.uk/support/en/product/SVS1512S1ES/updates
Rich
And which driver take care about the hotkeys? (FN + F1...), because only volume and brightness control works properly and touchpad, zoom and monitor don't
