Recently I bought a WD My Book 2 TB external HDD which I connect to my Vaio SVE1713M1EB through USB 3.0
However when I shut down the computer with the drive connected and then start manually, it doesn't start. It shows only the Vaio logo without loading Windows 8.
I need to shut down again (manually) then remove the drive to make it start. The curious thing is that the computer reboots normally even when the drive is connected. The afore-mentioned issue occurs only when shut down.
Any ideas?
Many thanks in advance!
Hi siegmund10,
There is a possibility that the machine is trying to boot from the external drive. To check whether this is the case enter the BIOS (with the drive detached) by pressing and holding F2 at boot when you see the VAIO logo. On the ‘Boot’ tab, if ‘External Device Boot’ is enabled then disable it.
On the same tab make sure the boot order is:
1. Internal Optical Disk Drive
2. Internal Hard disk Drive
3. External Device .
4. Network.
Save settings and exit.
Shut down, reattach the drive and attempt to start the notebook.
Rich
Hi siegmund10,
To rule out a problem with the device itself have you tried another computer? You could also try a USB 2 port assuming your computer has one.
If using USB 2 port solves the problem then it may indicate a controller problem on USB 3. Your model was released with both Windows 7 and 8 – not sure which you are running.
There is a driver available on the support site for the Win 7 OS but Win 8 has native support for USB 3 so no driver listed.
www.sony.co.uk/support/en/product/SVE1713M1EB/updates
To reinstall native Windows controllers it is necessary to delete them from Device Manager and then reboot – controllers will be reinstalled.
As the machine is failing to POST I would suspect a BIOS issue rather than controller but I may be wrong in this. As an experiment it may be worth enabling Legacy USB support, if that option is available, and see whether that makes a difference. If that option is not available try changing the boot mode from UEFI to Legacy.
Rich
Hi siegmund10,
Does the computer boot normally in Legacy mode without the external drive attached?
If it does then it would indicate that the system is trying to boot from the external drive. The cause is most likely a BIOS setting, but as you have checked that the internal drive has priority over the external drive in boot sequence, I have no clue as to which setting needs changing, especially as I don’t have a Vaio running Win 8 to refer to.
You could try setting the BIOS settings to default just in case something has been changed along the way. If this fails to work then reinstalling the USB 3 controller would be my next suggestion. I assume that you have run Windows Update recently – just in case Microsoft have updated the USB 3 controller driver.
Rich
Hi siegmund10,
This is a strange one and I agree that it is probably something to do with the Vaio configuration (probably the BIOS) – assuming that is that the drive does not prevent booting on other Windows 8 computers via USB 3 port.
Thalamus has kindly sent me a link from the WD data base that confirms this is a known issue.
http://wdc.custhelp.com/app/answers/detail/a_id/3701/p/228%2C209%2C316/session/L3RpbWUvMTM3NzA3ODQ4N...
If the option is available (I somehow doubt it is) then try disabling the SES driver in the Bios. Otherwise you will need to speak to Sony support as it would seem that a BIOS update is required.
Rich
