Hi Baby
I have a laptop Vaio E Series Sve1511 HFXW and install Win 7 on it.
I lost the cd Driver, I got into trouble
Coming to sony Support this Link:
https://esupport.sony.com/US/p/model-home.pl?mdl=SVE1511HFXW&LOC=3#/downloadTab
but any driver is not availabel,
Can you help me?
[updated subject title from SEV1511HFXH to SVE1511HFXH]
I see there is a firmware update on the US website for your model that is supposed to fix a disc not being recognised. Have you installed this?
https://esupport.sony.com/US/p/swu-download.pl?mdl=SVE1511HFXW&upd_id=8419&os_group_id=6
Why do you think you need a driver? The CD driver is usually part of Windows 7. Is the drive not working or is there a warning in Device Manager against the DVD/CD-ROM drive? If there is a yellow warning, in Device Manager under 'properties', please look for the Error Code and let us know what it is. There is often a simple solution for many common error codes.
As @Anonymous has said, this is a US Vaio Model and you may need to go to US-based support for any further assistance as drivers and other software are model dependant.
Hi Baby??
Farboud, I take it your model number is not SEV but SVE1511H as you mention in the comment itself, therefore I have amended the subject title accordingly, in case other people might look for a similar solution in future.
You'll find more info on how to find the model number here although I suspect it was just a typo.
I see that the link you had provided leads to a Sony US website. You might find more relevant information on the UK website here.
Sony have discontinued the sale of the VAIO line, but are still offering support, you can read more about that here. You'll see that that website also provides links to contact Sony Support, you might want to double-check the recommended drivers with them to be sure.
Best,
Arthur
Im sorry Arthur_K...
I cant find dirver i Lost my cd driver.
i cant install only Wifi Driver And Graphic Driver my model is Sve 1511HFXH
this link but i cant Download It:
you can Download it
no Im not install software in yor Link.
yes I need Driver Becuse Windows 7 can not Install Wifi and Graphic Card,I came to this link
and need Wifi & and Graphic If you have access link and you can download and send for me
,please help me
[Personal details removed by moderator]
