VGC-LN1M desktop all-in-one, 32 bit Vista.
I keep getting the message in the title on startup. I understand that Vaio Smart Network is not necessary for anything I need, and my networking works just fine without it.
Should I just uninstall it through Control Panel, download and reinstall it, or is there likely to be a deeper problem, ie it is something else that is stopping the program from working ?
Thanks
