Hi All
Thought I'd start a quick thread sharing some of my experience setting up hundreds of VAIO's over the years with a 3 step list to updating your VAIO when you first get it and keep it running in top working order.
From this list I'd personally choose
3. Once these have installed and you've rebooted, head over to http://www.piriform.com/ccleaner and get the brilliant CCleaner which fixes registry issues, provides a simple uninstaller tool to get rid of any other bundled software you don't want, cleans old system files etc etc. There are so many of these kind of tools on the market but these one I've always found the best. Its very robust, but as with any software, handle with care.I had a colleague who's machine was running really hot and taking ages to boot. Ran this tool, cleaned up something like 10gb of old system files and junk and it basically solved all the problems. So its definitely worth running this every couple of months or so.
4. Head to the Chrome store and checkout Adblock Plus - https://chrome.google.com/webstore/search-extensions/adblock%20plus This will block popups and adverts from most websites meaning a quicker browsing experience.
Feel free to ask any questions - these are my personal recommendations, but hopefully will help out..
Thanks
