It makes no difference whether I press thhe Scr Lk key (Fn+Num Lk). I have turned the laptop off and on. Still no change. Any idea?
JB
Hi JoeBath,
This is a long shot, but worth a try.
Shut down, disconnect the power adaptor and remove the battery. Hold down the power button for 30 seconds, reconect power adaptor and battery then reboot.
If that doesn't resolve the issue can you let us know whether ther is any code to the blinking or is it just constant?
Rich
