Hi
I have recentlu used my recovery disks to restore the system and now find that my dvd writer won't write. It will play back ok. Anyone help please.
MObanded
I have an RX405 and the only software that recognises the DVD burner is the Sony video software "Click to DVD".
Windows XP thinks it is just a CD burner so will not recognise DVDs.
Maybe yours is the same...
I havent tried Nero or other software.
Thats wierd Steve
There are firmware updates for your optical drive available here. Worth a try?
The firmware offered for the RX405 is for a toshiba DVD drive. Mine is fitted with a Pioneer drive, therefore no update exists.
thanks for the idea though.
At some point I will get a copy of Nero and give that a go.
Sorry, I was referring to the original post by MObanded and the problem with the RXG408.
