My Vaio RS504 is not in the same room as my router (Vigor 2600G with wireless lan). Is there a way to connect to the internet wireless from the RS504? As far as I can tell the RS504 does not have a pcmcia slot. Is there another way to do this?
Regards,
Rik.
Hi Rik,
Have you considered a USB wireless adaptor?
