I have a Vaio VGN A115s. Recently after logging into windows, the system fan goes into overdrive and makes a lot of noise whilst slowing down the whole system. Applications load really slow and the noise is terrible.
Has any had similar problems?? Any solutions?
hi
ı say nothing about the noise. Look out CPU usage when there is no working applications. if CPU usage more than %15 or %20 ı advise you scan your computer for viruses. If you could not delete or neutrilize viruses recover c disk. ı did it and it worked.
Hi Ohmz,
Could you vaio be overheating..?
Could you download MobileMeter and post back your Vaio's temperatures please...:smileyhappy:
Give your Vents a good blow,they could be full of dust ect.It could also be the Graphics Fan if you have one.
