Hi all, I was wondering if anyone else has this problem?
I have recently updated to windows 8.1 on my vaio pro, and now when the screen goes to sleep, I am unable to get it back on without hard rebooting the vaio. I have also noticed that, if left alone/inactive for a while, the machine randomly shuts itself down, losing anything I was working on at the time.
I have it setup in the power options to never turn the machine off, but to turn the display off after 10 mins.I have also updated all the drivers on the downloads page, but none of them seem to sort the issue.
I have only got the vaio a week now, and it's seriously starting to annoy me, especially for the amount of money it costs.
Any help would be much appreciated.
The graphics driver update solved my problem
Thanks!
Recently accuquired this laptop. Loving it.
My issue with with sleep after win 8.1 is that when I wake it from sleep or hibernation it will not allow me to change the brightness. So even the automated brightness is broken and it will either stay max bright (usually)
Sony should look into the automated brightness since it is a bit aggressive. With lights on in a bright lit room it still turns up to 100%
Seems there is a thread on going > http://community.sony.dk/t5/PCs-Accessories/Screen-brigntness-won-t-change-after-sleep/m-p/1378602#U...
After upgrading to 8.1, my screen resolution also appeared wierd although it seemed to be set on 1080p. What I realised was that the size of the text and other items had been maximised.
So did the following:
Hope it helps...
I too am seeing the same brightness problems on my Pro 13 after upgrading to Win 8.1
The brightness control on the F Keys no have no effect at all.
The driver update worked for me to fix the problem with Sleep and when the display turns off to save power.
Same issue here, driver did not fix the problem.
Also cannot find a working driver for the Sony Firmware Extension Parser, which was working fine in Windows 8..
Any help?
Many thanks....
Exactly the same problem with my new SVP1321C5E, after update to win 8.1.
When screen goest to sleep, it really sleeps... I have to reboot using the power button.
Help!
Windows update just installed an Intel Graphics Adapter WDDM1.1, 1.2, 1.3 Update. This seems to have fixed the issue for me.
