Do you think the VAIO Pocket is suitable for running with. I would like to go jogging in the morning's with my VP.
I have 2 questions.
1) What do you think the VP will be like when its moving around.
2) Does or has anyone ever ran with the VP, even to catch the bus 😜
Give me details,
Hornby!
Havn't been jogging with my vp yet, but I did have it running whilst doing a couple of hours work in the garden at the weekend including mowing the lawns so it got kinda bounced around quite a lot. No problems at all with the playback, worked perfectly!
Ok nice one.
Can i have some more feedback from people please, more so people who have been doing vigorous joking.
I recommend a 20gb NW-HD5 availble for less than a VAIO pocket ( I think), and is also smaller and much lighter. Also I have used an NW-HD3 and own a VP, and out of the two only the HD3 gave constant gapless playback. If I had the choice now, I would have an HD5.
its not very light, so make sure your tracky bottoms are tight-ish, could make for a very painful experience if your pockets are loose and they are set swinging if you know what i mean:smileycry:
my advice:
get a smaller one.
the Vaio is too big and uncomfortable.
a tiny 1gb/512MB player is the best option for jogging/doing sports.
my 2cents on this..
Has no one made a jogging band for VP yet?
I would suggest one of those tiny flash players Sony make, the NV series, then you can hang it round your neck while jogging
I have had my HD1 for a while now and I think the VP has the same G protection, it has never ever skipped on me even when Ive dropped it!
You should be fine with the VP although the weight issue may get annoying.
C
I've had two Vp's and neither have gave conitinous playback even when playing ATRAC3plus.
I've used it jogging. but only a couple of times. it was fine for about 10 mins then it skipped and crashed. had to reset it when i got home. my vaio crashes quite a lot tho so i'm not sure whether there is a fault with my unit, or whether this is common with others. looking through this forum it may be a problem with mine so i'll have to find out.
