i want to transfer pics from my DSC-T1 with out the cradles is there any cable(s) available that can eliminate the use of at least on of the cradles?
cheers guys.
If you search www.sonystyle.co.uk for DSC-T1 and click suggested accessories - cables/connectors then you will find the VMC15MU.AE - Multi-Terminal USB Cable which connects the camera to the PC for the grossly over inflated price of £20..
cheers man, you wouldnt happen to know if theres a t1 straight to ap1 cable without cradle cable do you? even if its still on the way and third party?
cheers.
I don't think there'll ever be one because the AP1 would have to have built-in support for direct camera connection.
