Hi,I was wondering if somebody has the same VAIO problem or knows something about this problem?I have a VAIO PCV-RS222 since several days the computer spontaneiously starts flashing with it's lights and starts beeping real loud.Just like it's on TILT.Does somebody know anything about this problem?[email protected]
Hi
I'm not sure if you mean you've had your PC for several days or that the problem has occurred over the last several days but....
This sort of thing usually means that your CPU is overheating. Make sure there isn't a build-up of dust on your fans. Also, have a look on the web for a CPU temperature monotor - sorry can't think of a site at the mo.
If your PC is only several days old then contact Sony.
check if its a display model..then it could be build up dust ..or..vent covered..if on a stand make the vented fan outlet be over the outlet slits or hole..then i could be it didnt like the coffee with sugar..that is inside?..try only blk without the sugar..peters went like it after jam inside the keyboard..4 year old did the deed..so he wasnt allowed to surf for a week..pc safe never take a kids swimming away..scared for life ..but it was a vaio..:smileypig: :smileyflag: redskins
