Hi
I hope someone can help me.
I have a VAIO PCV-LX2 which is running perfectly at the moment.
What I was hoping to do was disconnect the monitor and connect the base unit directly to my new TV/Monitor.
However, the base unit seems to have a unique connector socket.
Is there a way of doing this?
Thanks.
What does the connector look like? I would expect any monitor connection to be the standard 15-pin VGA Cable.
All monitors have this connection as do some modern TVs where it is usually called a 15-pin PC Socket.
Hi
This model has a different type of connector cable which is hard-wired to the monitor.
I've attached a picture of the one on my monitor (grey) compared with a standard connector for reference.
Thanks.
Ah - now I can see that you have a DFP connector. This stands for Digital Flat Panel connector which really did not catch on!
You can get an adapter which will convert your DFP output to a DVI-D connection which will plug into most monitors. If you want to then connect to a TV, you will probably need a DVI-D to HDMI cable.
http://www.lindy.co.uk/dfp-to-dvi-digital-adapter-cable-mdr20-m-dvi-d-f-0-2m/41221.html
I'll try that.
Thanks for your help with this.
