Hi, does anyone know if it is possible to upgrade the graphics card in this model laptop? i know it is possible to remove it and replace it. I have upgraded practically every other spec of this laptop, and i'm really looking to upgrade the graphics card, for its only 16MB ATI Radeon Mobility at the moment. Does anyone know if any other laptops share the same graphics card layout as this laptop?
Thanks!
Danh
Nope, you can't upgrade it, it's not possible
