Hi, I have had one of these laptops for over a year now and have broken the power socket ( where the power supply cable plugs in). Is there anywhere where I can but this part as I use my laptop daily and cannot do without it for work. Getting it fitted is no problem as I know a couple computer engineers that will do it. thanks
You could check with nexttronics, although they don't list your model they may be able to help?
thats a good site!!! they got everything
