When playing a video the computer seems to be locked in full screen mode and I am unable to access the controls which are not visible on screen. At the end of a movie the computer has to be re-started to return to normal use. How do I get the display back to normal ?
Hi TheFatOne,
Which application are you using to play the DVD?
Rich
It isn't a DVD, its any downloaded video and even the demo video that came with the computer. I am using Media Player Classic
I’m not familiar with Media Player Classic but have you explored the settings under View > Options for a setting such as Exit full screen mode at end of playback?
Otherwise try Windows Media Player, Windows Media Center or VLC Media Player.
Rich
Message was edited by: rich912
Do you encounter this problem in all the movies you play? The problem might be coming from the movie you are trying to play.
