Heey!
I have just bought a super cool Sony vaio c-series in a nice green colour !
Everthing is great about it, theres is just one thing i dont understand.. All over the website sony says that they have incredible dlna program to connect your vaio with a PS3 ? So far i have only discovered media go to connect to a PSP ? So i've google a bit and found the program vaio media plus, which you do the trick with PS3 but i cant seem to find it on my vaio ? how come ? and can i donwload it anywere ? is that a fail or have they stopped using the program ?
Hi Daniel,
As far as I’m aware Vaio Media Plus is still installed on most modern Vaio notebooks.
For my particular model it can be found by clicking Start > All Programs. The location of the executable is C:\ Program Files\Sony\Vaio Media plus – your model may vary.
If you state your full model number we may be able to confirm whether or not this software comes pre-installed.
Rich
I already looked in program files, it simply not there..
My model number is: VPCCA4C5E
By the way thanks for answering so quickly
Hi Daniel,
Unfortunately the full specifications for your model, including details of pre-installed software, are missing from the Support site. We are hoping that this will be rectified shortly – don’t hold your breath though...
Try calling the free phone number contained in the following link and, as you are thinking of buying this model ;-), ask whether Vaio Media Plus comes pre-installed.
http://www.sony.co.uk/product/vn-c-series/vpc-ca4c5e
Rich
Okay thanks for your time :smileygrin:
