why does the wireless connection on my VGN-NSIIJ_S switch off after a couple of mins
Hello,
Maybe it´s the battery mode, have you checked the batt mode? some modes switch off the wireless connections or optical units, check it and say us about it please.
p.s. forgive my poor english.
franktfe, Thank you for the info. Unfortunately not sure how to check or correct battery mode. Can you help?
Thanks again.
