I recently replaced Vista after 6 years with a clean install of Windows 7 x64. However, my Fn keys do not work along with S1, S2 and CD/DVD eject button.
Any thoughts please.
Hi navstar5.
Have you reinstalled the Windows 7 Drivers and Utilities?
You can download them by going to the Support pages for your model here: -
http://www.sony.co.uk/support/en/product/VGN-Z21WN_B/updates
Look inside Latest Downloads -> Windows 7 and install all the relevant drivers & utilities.
For the Fn Keys you need to install: -
Setting Utilities Series
Sony Shared Library
Vaio Event Service
Vaio Original Function Settings
You may also need to reinstall the original SFEP Driver from the Vista downloads.
Have a look in Device Manager to see if other drivers are needed - are there any yellow warnings (!).
Hi navstar5.
Sony Shared Library
Vaio Event Service
