Hi - I'd appreciate some suggestions - C:\utils\utils.exe did not resolve this and I dont want to go back to the recovery disk if possible. Below is the problem in detail:
I downloaded SP2 and my VGN-A197XP was working fine
I then downloaded the VL website SP downloads and am experiencing problems with HOTKEYs + DVD eject:
(1) can't turn brightness button OFF - it comes on when machine boots up
(2) vol up & down , magnify and S1 (hibernate) no longer work, although mute button does.
(3) can't eject DVD's
ENDS
Make sure you have a link from the utils.exe in the startup folder on the start menu.
I would re-download the utils from VAIO-Link.com
As a last resort try uninstalling SP2 and try reinstalling again, this worked for me.
If there are any Sony updates that are recent (ie maybe for SP2) instal them post SP2 and the rest pre SP2 install.
Test hotkeys etc after each install to pinpoint problem update.
William
William
