I'd like to calibrate my new Vaio to use it as a graphic portable station.... the icm profile by default is the sony l65 !
When I look pictures through windows image viewer, the colors don't appear the same as in Photoshop Elements pre-installed Sony version ! I cannot start Adobe Gamma loader when I double-click on it and I threw it away form the start up menu !
Well, I d'like to have exactly the same colors in that Photoshop and every Adobe programm I'm going to use soon.
No contrat set-up on that powerful dual lamp X-black screen ? Do I have to turn the light at the maximum to get a real white ? Well, thanks a lot for any hep so that I can use that notebook as a grahic station.
Thanks in advance.
Steph
Photoshop use differents Colorprofiles. You must use the same profiles with your VAIO.(for example AdobeRGB or sRGB)
Ok thanks, I chose Adobe RGB (1998) and everything seems now to be ok ! Did you have to pay for a recovery dvd at Sony support? I wrote mine
LOL, no
As I bought my VAIO for approx two years ago, I've get my VAIO "with" recovery DVD. But the new VAIO come only without. Last week was here a lot peoples, they must pay.
Because they have deleted the Recovery Partition before they have burned the DVDs.:smileyrolling_eyes:
