Hello
I have a sony vaio VGN-AW41MF_H and when a press the button Fn+F5/F6 the bright does not ajust...
what should i do, why this button does not work? help me please?
should i instal something in my pc?
Hi danu15,
Assuming that you are using the original operating system (Windows 7 Home Premium (64-bit) try reinstall in the following utilities in the given order.
• Setting Utility Series
• Sony Shared Library
• VAIO Event Service
• VAIO Control Center
• Also, if you have installed your own OS, the SFEP driver needs to be correctly installed (first) from within Device Manager.
You will find all these on the support site.
http://www.sony.co.uk/support/en/product/VGN-AW41MF_H/updates
Rich
Hi danu15,
Rich
