Hello, I had to change the preinstalled WMC with a WinXP Pro. Everything right till this: I have just an unknown "PCI device", no modem and no audio. The Sigmatel audio driver installer tells that the object af the device couldn't be find, and an update driver doesn't accept the modem driver.
I don't know exactly what to do now...
Can anyone help me?
Thnx!
Can anyone help me?
Thnx!
Hi ocatarineta,
Welcome to Club Vaio,
Thank you!
Did you download the <a href="http://www.vaio-link.com/downloads/preinstalled/preinstalled.asp? l=en&category=-1&serie=-1&m=2152" target="_blank">Preinstalled Drivers and Utilities</a> for your FE11s
Yes, but the provided one doesn't work. I don't think there can any drivers relevant difference between XPPro and WMC, so, any idea?
Yes, of course I did, and this was the same there was on my HD. But in XpPro doesn't work...
Yes, I did. This was the same drive I had on my HD. In WinXp doesn't work...
Ok, I did solve it patching with kb83522.
Bye!
Bye!
Glad it's sorted.
Why the hell did you remove WME????
FE11S has Windows XP PRO including the Media Crap you get. You are wasting your time dude. I have also FE11S you are wasting your time if you dont believe me just take more trouble then looking in your system properties....
Geez.....
Dear Sir,
I have the same problem PCI Device, any one can help please
