i can t connect my vaio on my plasma screen with a vga cable.
I have activate the output on windows but nothing.
I worked with my old compaq notebook.
What can i Do..,???
THX
Did you use your FN+F7 button? If not that is your solution....since you said you activated it on windows....
yes that s what i did when I said "activated on windows"
Try this one
Set the cursor somwehre within the desktop area, press the right mouse button and select "Nvidia Control Panel".
Then select "Display" and activate "Multiple Displays". There you have some options to set your displays and should be able to connect your flat screen.
At least that was the way I installed my Hyunday L90D+.
Perhaps it works for you too.
Oessi
