I own a FE11M, and the battery icon(on the bottom-right of the window), when the power adaptor is plugged in, looks as the battery still charging, even at 100% of charge
I also noticed that windows power management (the window that reveals the % of power left in the battery), doesn't indicate the time (in hours and minutes) remaining before battery goes down
Is there any way to fix these bugs?
As far as I know it always says its charging when the power supply is plugged in even if its 100% full.
Mine is 100% at the moment and its the same as yours...:smileywink:
Same problem here. I had a Toshiba and that showed me the remaining time of my battery. Also, how can I reduce the CPU speed in the power management. The tool seems to be pretty unflexible on the sony compared with the Thosiba...
Thanks for help,
best
nils
Thanks for help,
