I just want to update my FE11s to 2 Gb total of memory, what are the compatible ones? should it accept DDR2 667or only 533 ones? besides I´d like a 7200 SATA drive, any ideas?
Big Thanks
Hi guitarguy,
Crucial's System Scanner will automatically detect your computer's RAM information and give you the details you need to purchase a compatible upgrade for your Vaio FE11S.
Thanks,
Your welcome guitarguy.
