Hi, on other people's docks how seure is the connector that plugs into the vp? I was looking at mine this morning and it seems to be very loose, it moves left and right, forward and back. Is this the same on all docks?
Hi Ben,
mine moves from side to side by about a millimeter, but does not feel all that loose when doing so. (it actually didn't move at all, untill I started poking it to see how much it moved
Josh
cheers josh, i had a look at my brother's dock as well and mine is quite loose compared to his. i hope it's nothing to do with the number of times my dock has fallen over - light stand with lots of cables and a heavy object on top =
