what do i need to plug a vaio desktop lcd display into a vga or dvi input on my vaio laptop. The desktop display has around 30 pins.
Hi peterbelic and welcome to the club.
Have a look HERE and click on Cable Finder. You should be able to identify the two connections you need and see if there is a suitable cable.
You don't tell us your Vaio model but most have a VGA 15 pin monitor output (HDDB 15). Not sure what monitor connection you have - you will have to search for it.
The monitor came with the vaio pcv lx1desktop and the monitor is a pcva-15xa2 . Could not see the exact connector in the link you sent
I think the LX1 has a DFP connection (Digital Flat Panel).
DIGITAL MONITOR CONNECTIONS
This is a digital only connection. You can buy a DFP to DVI converter to attach to your DVI port.
