I damaged the cover of my Vaio. Has anyone had the same problem and can tell me something about the price to repair it? Thanks!
Message was edited by: sahinnwy
Hi there,
Let me know which vaio you own and i may be able to help you getting a new cover. To be clear we are talking about the back of the screen, with the vaio logo, right?
THanks, Oliver
Hi sahinnwy,
welcome to Questions & Answers..:smileyhappy:
You could try contacting one of Sony's authorised repairers to see if they'll supply the part you require..
To find contact details open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab to locate the nearest location.
