I have recently bought a VAIO VPCSE1C5E.
In control panel under uninstall programs there are a program called "VAIO CPU fan diagnostic" but I can´t find where it is installed. How do I start that application?
\Program Files (x86)\Sony\VAIO System Diagnostic\CPU Fan Diagnostic\FDU.exe
maybe in bios! i don„t know exactly:)
then what?
how do you open that mui file?
You must \Program Files (x86)\Sony\VAIO System Diagnostic\CPU Fan Diagnostic\FDU.exe in search and all is ok !!!
how can I cool down the fan of sony sve15135cnb laptop to improve my performance
i have found the tool but after running it it didnt gave any result
