i tried re-installing all the my drivers and utilities and i have noticed that after re-installing the vaio control centre, alot of options (inluding the use of S1,S2 buttons) have been removed. How do i find the control centre that is for my laptop?
Hi AntonisCy,
why did you need to re-install all of the drivers and utilities on your Vaio.
The pre-installed drivers can be downloaded from HERE unfortunately it doesn't look like the utilities are available for your model though..
