I want to know if i can use the memory stick slot for my memory stick Duo on a PSP?
If your Vaio is modern enough then it will directly accept the duo.
What model Vaio are you using?
If you connect your PSP to your Vaio using a USB cable then the memory stick on the PSP will show up in "My Computer" as another drive.
Altrernatively. if your your Duo Memory Stick came with a Memory Stick adapter you can insert it directly into the memory stick slot. by firstly putting the Duo inside the the adapter.
Can't you connect wirelessly?
That's odd, but maybe it's a handy security precaution
Modern Vaio Computers don't require the adaptor.
Most VAIO notebook has got a Memory Stick slot, you'll need to buy a memory stick duo which comes with a memory stick duo adaptor. You slide the MS Duo in the adapter and then put it in your laptop which got a ms slot.
see the link for a pic.
http://drmobil.hu/images/memkartya%20duoadaptor.jpg
No. wireless ad-hoc function doesn't let you transfer files.
