I bought my first Vaio and I was forced to reinstall Windows (XP Pro).After all driver installations, I cannot install sound driver - Realtek , he says - please install Microsoft BUS driver before!!!.
And another thing - my bluetooth is always on!! I don't have software for it.
Can someone help? Any ideas? Thank you!!:smileycry:
had to try to update your vaio?.. maybe there is some kind of software that can help you switch it off?
had you try to update your vaio?.. maybe there is some kind of software that can help you switch it off?
may be a silly question but is anyone having probs with getting the wireless mouse to work with their vaio. Got an a317s. new to the 'joys of vaio' so any quick answers appreciated.
thanks
nine
har same as mine... cool stuff uh? :smileygrin: .. well once you put in all the batteries in the mouse, turn it on, there is a button under it.. then turn on your laptop, tilt it abit.. better off the docking station first, you will find a small button (round n white) under your right hand side of the laptop.. better if you put your laptop at the eage of the table.. easy to see under it.. then.. press it on the same time press the white button (connect) under your mouse too. and it should be working by now hehehhe
Yeehh... Vaio mouse is crap. Very "unhandy".
As for bluetooth - still same problem. There should be utility or software called bluetooth gate or something. Any ideas where to download?? And same stuff with wireless - need wireless switch utility. Anyone..?
