I am about to purchase a Belkin Pre-n wireless adsl router.
Has anyone got experience of using this? I have a Sony A497XP.
Thanks,
Tony
Hi
I have a belkin access point, connected to a SMC Barricade modem router, and have always found the Belkin to be a reliable piece of kit, it is simple to use and simple to set-up. If you are not sure, see if you can download the manual from the Belkin site, and have a look at the set-up procedure. This may give you an idea about the complexities of the installation.
Atticmaster
Thanks very much.
No problem
It's nice to have somebody reply once in a while
Just started a new thread, and would welcome any help. Problems with internet speed using the Belkin Pre n.....
Would appreciate if anyone could take a look,
Thanks
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=33447
