I bought my VGN-FS215S in the UK and I'm now going to the states for a year. From the documentation it looks as if the power pack can just be plugged in in the states, is that right? What else, if anything do I need to do/buy/take to use the laptop with US utilities?
Thank you!
Hi Eloiser and welcome to Club Vaio.
Yes your power adapter will be OK as it accepts an input voltage of 110 - 230 volts.
Apart from changing your Spell Checker your Vaio should work as usual in the US.
You may wish to consider purchasing a worldwide warranty from Sony if your Vaio is under a year old.
What model do you have? - just in case it has something UK specific.
Dohhhhhhhhhhhhhh!
I must get more sleep!!
