What kind of USB port does a vaio pcg-fx203k have? Is it the basic or high-speed version?
Thanks
Right click My Computer go to the hardware tab then click on device manger, go down to Universal Bus Controler (probably at the bottom) expand the list and it should tell you there. USB 2.0 is the high speed and 1.0 and 1.1 are the standard ones.
