Hi I have a VGN FS485B that I purchased in June.
All of a sudden the second USB port is not working what so ever.
I did a system restore back a few days to a time when I knew it was working...
Any suggestions as I use the 2 ports all the time...
thanks
Hi Mallory,
I suggest you contact Vaio-Link as your Vaio is still within warranty. They will ask you to do a full recovery of drive C: as they always do before they will accept it for repair.
You could check Device Manager to see if all your USB Controllers and Hubs are installed correctly. You could uninstall them and reboot but I'm not sure it will help.
