Hi All,
Just wondering if anyone knew of any good 5.1 usb sound cards for my laptop, i looked on ebay a small one keeps popping up but i wanted some opinions first before getting one.
Thanks for looking and any advice would be great
here is the ebay link to one of the only ones that comes up
http://cgi.ebay.co.uk/USB-2-0-5-1-CH-Powerful-Notebook-Laptop-Sound-Card-UK_W0QQitemZ6870720089QQcat...
is it worth getting? the sound out of notebooks isn't brilliant, and i can't see it getting much better with a new sound-card- unless you use external speakers? i guess you do, otherwise why 5.1?
Depends what quality you want and how much you are prepared to pay.
The one on ebay I don't know about - I'm not sure you will notice a big improvement over plugging a set of amplified speakers into your earphone socket
THIS ONE is THX Certified and 24 bit and is PCMCIA connected. Supports 5:1 and 7:1.
THIS ONE is USB Connected and supports 24 bit, 5:1 and 7:1.
There is a cheaper version that does 5:1 only but I can't find it.
Thanks for the advice, i will deff be looking into those which you said, its for some 5.1 videologic speakers i got. Want them for movies i watch and some more spekers for music around my room
The THX card really needs a good home cinema pair of speakers
