- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
USB PORTS
I'm having a problem with a few pieces of hardware connected to my USB ports:
Lexmark x85 printer,scanner, phtocopier
Labtec Webcam.
Every time I reboot my VA!0, I have to reinstall the lexmark software and disconnect and reconnect the USB cables. With the Webcam I just have to reconnect the USB cable.
Atfirst I thought it was my printer at fault but I have proved it onanother computer without any problems.
I'm running XP Professional
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try getting the latest drivers from Lexmark and the other company. It could help, otherwise use some kind of hub.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your help. The problem isn't with lexmark it is either with the Sony hardware, Sony software or my OS. I was wondering if there were any known issues with the Sony WA!0 and USB peripherals
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not usually, Sony USB ports usually work well. What CPU does it use. Maybe you need to get a USB filter driver.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Intel Pentium 4 2.4Ghz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm not sure if intell have a USB filter, check out vaio-link and Intel's site.
