Just wanted to know is it possible to upgrade my graphics card on my pc? I currently have the PCV-RX405 with a NVIDIA GeForce MX460 graphics card. Can I just take it into any a computer store. is there any good online places that can upgrade it? Cheers
Yes, you can take it to a store, but if you know what AGP speed it runs at, I'm sure you can find something suitable and fit it yourself.
how will i find that speed?
Download and run Aida32 from www.aida32.hu/aida32.php
It will give you more information about your system than you will probably ever want to know.
I've just tried Everest Home edition from http://www.lavalys.com it is also very good.
or download 3D Mark 2003 tells u all about ur PC
u need to check if compatible AGP x4 or x8 depending on card u wanna get, also chek power supply some cards require 400 watts
i have a RX 501 which i assume isn't all that diffrent to yours and i was able to put a Gforce FX5900 no problem eventhough my sony is only 275watts (apparently sony has good components and can handle more)
if u r not sure the i suggest u bring ur PC to computer store to chek with them (even if u don't buy ur card there) it would suk if u got a 300$ card which won't run
u might also want to add an extra fan to cool down ur computer (they r cheap, a simple noise bloker is less than 15$ and silent less than 20db) since graphic cards can generate a lot of xtra heat even if they have a built in fan
Cheers for the info i'll check it out! Is there plenty advice out on fiitting on these?
Im back. just found its supported 1x, 2x, and 4x and is currently running at 4x. After having a look around most of the top ones are 8x ( hard to find any specific 4x). I did find one on ebay that said it was compatible = NVidia Geforce FX 5950 Ultra 256MB AGP DVI any good? will it work on my computer? cheers
Greg has a similar one so it should work
256 MB graphics card should be good, and I found the Geforce not to be too bad.
Still I perfer ATi
Just had a look around on the net a its seems alot people on forums reckon 8x graphics cards are bacwards compatibable with 4x?
