Hi Folks,
I'm looking for some advice on upgrading the memory on my FE21B from 1GB to 2GB. The 1GB sony memory module is over £200 but i can buy two "guaranteed compatible" 1GB modules for £120. Does anyone know if these are OK or should i steer well clear- i just don't want to have to spend ~£450 on sony modules if its not essential?
Hi digit2,
Most of us here in the UK use CRUCIAL.COM and I have never heard a complaint about the modules or their Guarantee.
The Sony pricing policy is impossible to defend - it is 'bought in' from outside suppliers like Samsung and not worth the money.
Enough of us use Crucial to be able to vouch for them.
Hi Blencogo,
Thanks for the info (again...you solved a problem i had before
). Crucial was the place i found the lower price so its great to know you guys can vouch for it. Thanks again m8.
