Hi all, I've got a VGN-AR41E and I'd like to upgrade the memory. At the moment I'm running 1x 1GB DDR2 @ 667MHZ. Now on the support it says my notebook can take up to 2GB, however would I be able to run 4GB, 2x 2GB DDR2 at either 667MHZ or 800MHZ? Surely this would work as it would be the same type, just bigger capacity? Any light shed on this is muchly apreciated! Thanks, Oli.
