Hi there, I was wondering if it was possible to upgrade the graphics card on notebooks (in particular the PCG-K2x series)? If so, can anyone recommend any graphics (any size, ideally 128Mb) with Pixel Shading?
Kind Regards,
Kenneth
Unfortunately it would be impossibleas the graphic chips are integrated on the motherboard.
Technically it is now feasible with removable cards but it has not really caught on yet.
Ah now I understand, whilst i'm fairly good with computers I never fully understood what intergrated graphics meant, so thanks
You say that techincally it is feasible with removable cards, is there anyway I could go about this?
Ah now I understand, whilst i'm fairly good with computers I never fully understood what intergrated graphics meant, so thanks![]()
LOL technology seems to be going backwards. I have a GR series (three years old) with the graphics on a daughter board.
But can you get an upgraded daughter board?
No idea, but at least I can replace it if it goes belly up:smileywink:
From past experience the rest of it will go belly up first
Thanks for that vote of confidence, but I have an F series (5 years old?) still giving good service. OK it has the usual capacitor problem but with APM disabled it is still in daily use by my daughter.:smileywink:
