Just wondering if it's possible and how easy it is to upgrade my CPU
I have a PCG-FX605 laptop, just added more memory to make it 512MB RAM... (in the instructions of how to open the laptop up SONY tell you to open the wrong 'hatch' the one they tell you to open shows the CPU not the spare memory slot) This got me thinking tht if you can gain access to it you muct be able to upgrade it!!! :smileygrin:
Is it possible and can anyone recommend any for me to replace my current one with? (currently running on orriginal AMD Athlon-XP 1500+)
Yes, it's possible from what I remember others saying.
Probably not much more than an Athlon 1800+
