Hello everyone, after a quick check on the forum I wasn't able to find anything on upgrading a vgn-cr41s.
Basicly I would like to know if it is possible to upgrade the CPU. I understand that there might be an overheating issue so if I am able to upgrade the CPU is it possible to upgrade the cooling? Like changing the fan and having it work at higher RPMs, maybe.
I was thinking of upgrading to an Intel Core i3 3220. I'm not sure if that is even slightly compatible with the rest of the componant and that's why I need expert help.
Thank you in advance.
Dean
